b1: [Req] Sequence convert with Folder tabs
Locked
In 1.82 alpha, tabs are used in Batch conversion. This is very good, but now Batch convert and Sequence convert behave differently, one has a subdialog for the "Transformations", the other one has a tab. :-|
If possible, this should be "fixed" in 1.82.
Re: b1: [Req] Sequence convert with Folder tabs
helmut wrote:In 1.82 alpha, tabs are used in Batch conversion. This is very good, but now Batch convert and Sequence convert behave differently, one has a subdialog for the "Transformations", the other one has a tab. :-|
Ok, i'll try
Ok, i'll try
Very good. :-)
:arrow: Confirmed.
Confirmed fixed in Beta 3. There's a 'Transformation' tab, now.
Locked
