XNViewMP: save format for "JPG (only)" ...?
Gerald_Ire
Post by Gerald_Ire »
hi all, try to shrink down options to maket XnViewMP eassier for user:
#1) Setup in XNViewMP under "save" format is JPG (only)...
When I am using the "file/save as" I can see more option so save the image (png, tiff, bmp etc) ...
Any idear or option to shrink thsi on jpg only?
#2) Should I customice the "write" options on "jpg"?
No clue how to do so. Editing the *ini failed.. :-(
Stay safe!
:D Gerald says thx to all! :D
Re: XNViewMP: save format for "JPG (only)" ...?
Gerald_Ire wrote: Fri Jun 25, 2021 12:35 pm #1) Setup in XNViewMP under "save" format is JPG (only)...
one question, why do you keep Guetzli?
Gerald_Ire
Hi Pierre, no special reason to keep "Guetzli". We can drop this and stay with the one "jpeg/jfif"..
This problem is supposed to be fixed in XnView MP 0.99.0. Please check and confirm the bug fix here.
