Export all pages from a Multi-page TIFF
corr
Post by corr »
I searched hard but could not find a way in the current XnView MP to export from a multi page TIFF all images lossless to separate files. Would be grateful for a hint. :)
Re: export all frames from a Multi frame TIFF
corr wrote: Fri Jun 25, 2021 2:14 pm I searched but could not find a way in the current XnView MP to export from a multi frame TIFF all images lossless to separate files. Would be grateful for a hint. :)
I think that option - inexplicably - hasn't been added to XnView MP yet (it would be expected to be found in the file browser)... :?: :(
However, good news, you should be able to do it using Tools > Batch convert if you configure the Output tab suitably, and Batch convert can be used for a single input file if required... :D
corr
Re: Export all pages from a Multi-page TIFF
Post by corr »
Yes, I forgot to write that I also tried batch conversion. It seems to recognize the number of pagess and generate images for them, but only from the first page. So a tiff with 13 pages generates 13 image files, but only with content from the first pages. So it seems to be a bug. I can't find any possible setting that could be a cause for the behavior.
Re: Export all frames from a Multi-frame TIFF
corr wrote: Fri Jun 25, 2021 4:46 pm Yes, I forgot to write that I also tried batch conversion. It seems to recognize the number of frames and generate images for them, but only from the first frame. So a tiff with 13 frames generates 13 image files, but only with content from the first frame. So it seems to be a bug. I can't find any possible setting that could be a cause for the behavior.
Possibly related to this apparent bug... :?:
corr
Post by corr »
Yes, probably the same function.
you would to convert multi page TIFF into a multi page TIFF?
corr
Post by corr »
I want to convert a multi page TIFF into a multi file TIFF (single page).
@corr:
Reading the whole thread again, it still isn't entirely clear whether you wish to:
A. Extract all pages from a multipage TIFF to separate single-page TIFF files.
B. Convert a multipage TIFF to a multipage TIFF file, presumably after editing the pages in Batch convert.
corr
Post by corr »
corr wrote: Tue Jun 29, 2021 10:28 am I want to convert a multi page TIFF into a multi file TIFF (single page).
Thats "A"
you can by enabling 'Convert multipage file to multipage file' in Batch convert
corr
Post by corr »
As I said, I tried that, but I only get the first page in all the files.
corr wrote: Tue Jun 29, 2021 1:05 pm As I said, I tried that, but I only get the first page in all the files.
could you post a screenshot of output tab?
Are you possibly trying to convert multiple multipage files to new multipage files?
I have no problem converting a multipage TIFF to a multipage TIFF using XnConvert 1.90 with 'Convert multipage file to multipage file (when possible)' enabled.
When you view the pages of the output file in XnView software, are you using the small arrows on the toolbar to step through the pages, if they exist, the large arrows will step between the first pages of multipage files?
corr
Post by corr »
cday wrote: Tue Jun 29, 2021 1:13 pm
No, thats not what I want. Its:
corr
Post by corr »
xnview wrote: Tue Jun 29, 2021 1:13 pm could you post a screenshot of output tab?
