What's the recommended file list
obelisk
Post by obelisk »
What's the recommended file list custom filter?
Video has 4 types of extensions, and I odn't know what should be in each
mine is from so long ago and many times videos don't play corectly
Re: What's the recommended file list
the extension of the videos (that don't play) are in the list?
obelisk
Post by obelisk »
mp4
you have it in the list?
obelisk
Post by obelisk »
yes it's there
not all mp4 fail, some work some stutter some dont play
obelisk
Post by obelisk »
m2v mpa m1s mpg mpeg m4a mts m2ts mpm mp4 m1v mpe
does it matter which of the 4 it's under?
obelisk wrote: Fri Jul 09, 2021 9:52 am yes it's there
please send me one file?
obelisk
Post by obelisk »
No I just wanted to understand what the 4 lines mean
obelisk wrote: Mon Jul 12, 2021 9:08 am No I just wanted to understand what the 4 lines mean
it's only video extensions
obelisk
Post by obelisk »
What makes some mp4 can play some can't?
Sorry I can't find any mp4 I can post, and try to make mp4 from my phone they all play.
masterjp
Post by masterjp »
MP4 Files is a video file container only (like mkv). You can check the used video codec and audio codec within the mp4 file.
Maybe it is an exotic format or you do not have installed the right video codecs on your computer.
You can check the used video and audio codec of the file with:
MediaInfo:
https://www.videohelp.com/software/MediaInfo
A good choice for problems with video/audio playback problems are the lav filters.
They are used in different video players to playback many different file formats.
LAV-Filters:
https://www.videohelp.com/software/LAV-Filters
obelisk
Post by obelisk »
I figured it was about video codecs. I use MPC-HC as a player normally. It's fine there and on WMP. Does it use the same stuff?
masterjp
Post by masterjp »
I use the MPC Player, too.
The MPC Player has an internal video and audio filter for correct playback of files.
It is a good universal video/audio player for different formats.
That is the reason, why it works with your files. It is based on the latest lav filters.
I think XnViewMP use the same video/audio filters from december 2020.
They should playback most of the video/audio files.
Can you tell me, which video/audio codecs are used in your video file?
In MPC Player you can check the file properties in one of the menus.
These informations could help:
Video:
Resolution (width/height):
Video codec:
Bitrate/s:
FPS (Frames per second):
Audio:
Audio codec:
Bitrate:
Channels (mono, stereo, 5.1, etc.):
Maybe I have a file with the same properties for testing it in XnViewMP.
obelisk
Post by obelisk »
Working:
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 2.08 MiB
Duration : 45 s 60 ms
Overall bit rate : 386 kb/s
Writing application : Lavf58.9.100
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings : CABAC / 8 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference : 8 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 384 kb/s
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Frame rate : 23.879 FPS
Minimum frame rate : 11.940 FPS
Maximum frame rate : 53 800.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.052
Stream size : 2.06 MiB (99%)
Writing library : x264 core 148
Encoding settings : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=15 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=22.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Codec configuration box : avcC
Broken:
Format : MPEG-4
File size : 884 KiB
Duration : 5 s 156 ms
Overall bit rate : 1 405 kb/s
Writing application : Lavf57.41.100
Video
Format : AVC
Format profile : High@L4
Codec ID : avc1
Bit rate : 1 401 kb/s
Width : 640 pixels
Height : 1 144 pixels
Display aspect ratio : 0.559
Frame rate mode : Constant
Frame rate : 29.094 FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.066
Stream size : 881 KiB (100%)
Writing library : x264 core 148 r276 3f5ed56
Encoding settings : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=36 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=22.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
