0.98.4: Fullscreen does not show info for first file with vTab=126
Hacker
Post by Hacker »
XnView: MP 0.98.4 - 64 bit
OS: Windows 10 20H2 - 64bit
xnview.ini:
[Preview]
vTab=126
[%General]
enterMode=2
Effect: Upon pressing Enter on a file in the browser, XnView MP switches to fullscreen but does not show information for the given file. Pressing PageUp / PageDown switches to another image and the information is now shown correctly.
1. Place an xnview.ini as above into XnView MP's folder.
2. Navigate to a folder with at least two images.
3. Press Enter on the first image.
Actual behaviour (bug): XnView MP shows the image fullscreen but without the image information in the corner :bug:
Expected behaviour: XnView MP shows the image fullscreen with the image information in the corner.
4a. If you navigate to the next image using PageDown, the information is now shown for the second image. If you use PageUp to go back to the previous image, the information is now shown for that one as well.
4b. If you press Enter six times, the information is now shown correctly for the image.
TIA
Roman
Re: 0.98.4: Fullscreen does not show info for first file with vTab=126
I've tried but can't reproduce, do you have started from a clean .ini?
Hacker
Post by Hacker »
Hi Pierre,
I have made a video capture of the bug:
https://youtu.be/4Pfr97OgP1k
I press Enter (info in upper left corner not shown), Page Down (info shown), Page Up (info shown).
And yes, that is the xnview.ini I am starting with:
[Preview]
vTab=126
[%General]
enterMode=2
Roman
ok, it's a duplicate
