R-Click displays unexpected context menu [Solved - Mouse problem]
Back in Windows 7 temporarily with an unexpected problem:
XnView MP 0.98.4 Tools > Settings > Interface -- Mouse --Right button set to Move picture
But a context menu is displayed:
Re: R-Click displays unexpected context menu
This is clearly the Shell Extension running, which I have never knowingly launched...
I did download all three versions of XnView Classic some time back, and may have launched the full version, would that have launched the Shell Extension automatically? My Windows 7 is 64-bit.
I need to use Windows 7 temporarily to run software that can't be run on Windows 10, but haven't been able to find any running program or process that I can uninstall or kill. I need a simple way to deactivate the unwanted utility and restore my normal mouse operation, please.
It's MP's regular context menu for view mode.
Please take a look at screenshots of the shell extension for comparison.
  • If the dimensions of the viewed image are smaller than or equal to XnView's window size, a right mouse button click on the image invokes the context menu.
  • If the dimensions of the viewed image are greater than XnView's window size, clicking on the image with the right mouse button and holding down the button will allow you to move the image (mouse cursor changes from pointer to hand).
What is your configuration for Tools → Settings… → View → View → Auto image size?
XnTriq wrote: Fri Jul 16, 2021 1:00 am It's MP's regular context menu for view mode.
Thank you for that useful insight, I've never used or even thought of using the Shell Extension...
It was set to Last used but selecting alternative options didn't seem to make a difference.
I tried deleting my ini file, I'm attaching the new one in the hope that it might enable someone to identify the problem... :?:
xnview.zip
cday wrote: Tue Jul 13, 2021 10:58 am Back in Windows 7 temporarily with an unexpected problem:
Sorry but i don't understand the problem?
xnview wrote: Fri Jul 16, 2021 11:08 am
The right mouse button is set to move the image, but when I press it I can't drag the image, instead the context menu in my first post opens immediately...
I don't see any way to disable it... :( :(
same on windows 10?
xnview wrote: Fri Jul 16, 2021 11:25 am same on windows 10?
On checking, quite unexpectedly it is... :wink:
And surprisingly the same in Linux Mint Cinnamon 20.1 or 20.2 deb
I've never seen this behaviour before, a bug in 0.98.4 maybe??
Different problem in 0.98.3:
Right button set to Move picture -- Nothing happens...
cday wrote: Fri Jul 16, 2021 11:59 am Different problem in 0.98.3:
i have no problem to move picture with right button, and with a clean ini?
xnview wrote: Fri Jul 16, 2021 12:11 pm
I have no problem to move picture with right button, and with a clean ini?
I tried that earlier, and I've just tried it again although the uninstall of 0.98.3 wasn't completed correctly.
Really strange that I have the problem independently on separate Windows 7, Windows 10 and Linux computers, I have never had an issue before.
Testing 0.98.0 on Windows 10, the same computer used above, I have the context menu again...
The issue was first seen on my Windows 7 computer with zoomed images, some at least of my quick tests today were not valid as the test image wasn't zoomed, sorry.
Nonetheless, I stlll saw a context menu in one test with an earier 'MP 0.98 version??
I'll do some more tests later, I really need it on my Windows 7 computer with its large screen.
Update: Windows 10 and Linux Mint with 0.98.4 now operating correctly when image zoomed.
Possibly an issue specific to my Windows 7 installation??
:shock: i've tried on a clean win 10 with a clean ini (the setting is by default), and no problem, same on linux
xnview wrote: Fri Jul 16, 2021 12:38 pm :shock: i've tried on a clean win 10 with a clean ini (the setting is by default), and no problem, same on linux
Thank you for testing, the problem seems to be specific to my Windows 7 computer, but I have never seen anything like it before... :?:
Interesting that the context menu displayed is seemingly not the XnView Shell menu, thanks XnTriq... :D
And seems unlikely to be a functionality downgrade in the British download ordered by M Macron or the E.U. :wink:
Please follow these steps:
  1. Go to Tools → Settings… → Interface → Mouse and make sure that Right button is set to Move picture.
  2. Activate Show scrollbars in Tools → Settings… → View → View.
  3. Open an image and zoom in until the scrollbars show up.
  4. Click on the image with the right mouse button and hold down the button.
Does the mouse cursor change from pointer to hand?
