I have BMP-file generated as a screenshot by Macrium Reflect 7 Recovery Tool (it is attached for your reference as 7-Zip archive).
It is rendered incorrectly by XnViewMP 0.98.4 (all texts are missing, etc.), though other programs (even mspaint) render it correctly.
It also looks incorrectly when exported with XnViewMP into PNG-format, and this exported version is rendered identically in all programs (I guess, XnViewMP cuts out some crucial data when reading the BMP-file).
OS: Windows 10 64-bit (Version 10.0.18362)
0.98.4: Incorrect BMP rendering
AntonK
Re: 0.98.4: Incorrect BMP rendering
this file has bad alpha channel, please use 'remove alpha channel'
AntonK
Pierre, thanks for looking into this.
Can the app detect broken alpha-channel and remove/ignore it automagically when rendering?
i can't detect if alpha channel is bad or not
