Display question 0.98.4
blackxacto
Post by blackxacto »
1. Somehow the XnViewMP opens to folders only. So I must find the one folder I only want to display.I only need display one folder ever. I know I changed this, but I thought I had changed it back to where the app opens to only the interior on one folder. Anyway, what is setting to display the contents of one folder every time I open XnView?
2. Is there a way to keep the cache display of one album so XnView does not have to rebuild default image icons each time I start up XnViewMP. Maybe I turned this off. I thought I turned it back on.
Would appreciate any help.
Learning to mind my own business. 8)
blackxacto
Re: Display question 0.98.4
Nevermind. I found the correct settings in Preferences.
Is there a way to save the hidden settings file, so it is easier importing workable settings?
