XnView: MP 0.98.4
OS: Linux 64bit
I'm experiencing a bug in which the AVIF and JPEG XL formats do not appear in the About/Formats menu, or in the "Save as" menu when saving a file.
0.98.4: AVIF & JPEG XL formats not appearing
GoatGoat
Re: 0.98.4: AVIF & JPEG XL formats not appearing
currently the plugin exists only on Windows
u880
I' using Debian Linux 11 (Bullseye, 64 bit) and I just upgraded XnView MP to 0.99.6: is AVIF still unsupported on Linux? I have a growing number of AVIF images and cannot open them (I don't have the need to save them, just reading/viewing is currently necessary). It's also not listet in "About XnView MP" -> "Formats".
If it's still not supported: are there plans to support this format in the Linux version too?
Thanks and kind regards
yes but don't know when yetu880 wrote: Sat Dec 18, 2021 11:50 am If it's still not supported: are there plans to support this format in the Linux version too?
u880
Great, thank you Pierre.
u880
Hi Pierre,
one year later I just downloaded version 1.4.2 but it seems that AVIF is still unsupported on Linux. Are there any news when the plugin will be available?
AVIF in reading will be supported with libheif in next versionu880 wrote: Sat Jan 28, 2023 12:06 pm one year later I just downloaded version 1.4.2 but it seems that AVIF is still unsupported on Linux. Are there any news when the plugin will be available?
u880
Hi Pierre,
that is good news - thank you very much for the update.
Kind regards
Kind regards
