"Save Selection" does not provide removal of OCRs.
josedumoretzsohn
Post by josedumoretzsohn »
[MP 0.98.4 x64] I just found out that an image saved through the "Save Selection" command cannot have their OCRs removed, probably because the remover application does not recognise the text on the image, although the OCR removal works correctly if the same image is saved through the "Save As" command, probably because the remover application does recognise and therefore extract the text on the image.
josedumoretzsohn
Re: "Save Selection" does not provide removal of OCRs.
I'm sorry about this posting. The non-removal was not a process error. I must think it over, to find out why some OCR cannot be extracted.
