HEIF/HEIC on Linux?
JimDossan
HEIF/HEIC on Linux?
Post by JimDossan »
Hello everyone!
Searched the forums, but so far I only found the same question in some comments with no answer.
On Linux, can XnView MP support HEVC compressed photos (be it via plugins or other libraries), especially the thumbnail generation?
I found a thread on Reddit that talked about having libheif1 and libheif-dev installed, but that didn’t work for me so far on Ubuntu 20.4 LTS
Re: HEIF/HEIC on Linux?
currently it's only supported on Windows/MacOS
JimDossan
Post by JimDossan »
Thank you for the answer, now I can stop wondering whether I'm doing something wrongly! :D
Then I'll have to use some other software for viewing the files while on Linux for now. Thanks again for all your work!
nightflame
Post by nightflame »
Is HEIF/HEIC supported on Linux yet?
nightflame wrote: Fri Dec 29, 2023 7:10 am Is HEIF/HEIC supported on Linux yet?
yes you need to install libheif
nightflame
Ah I found I needed to install libheif-dev specifically to get this to work.
Thanks
brst
Post by brst »
nightflame wrote: Wed Jan 03, 2024 10:32 am Ah I found I needed to install libheif-dev specifically to get this to work.
Great! This works for me too! 8)
Thank You!
fbachofner
Post by fbachofner »
On Fedora this package is named
libheif-devel
So:
sudo dnf install libheif-devel
Some additional (Fedora) libraries I have found to be useful to load heic/heif when using other image viewing programs such at Shotwell, qView and showFoto / digiKam are
  • libheif-tools
  • libheif-freeworld
  • qt-heif-image-plugin
  • heif-pixbuf-loader
XnView MP and XNView 2.x
on a variety of Linux machines
(and a couple Windows boxes)
