B1: Batch Convert: Close dialog after conversion
Locked
After Batch conversion, some people want the "Batch Convert" dialog to close, others want to keep it open.
Perhaps a good way to serve both needs is a checkbox
[x] Close dialog after conversion
Ho, yes!
• Hi !
- I agree and support this !
- That bores me for years…
- Maybe only a hidden INI entry could do the trick too, and should cause a smaller work to add ? Anyway, the entry shall exist for the option…
Dreamer
Post by Dreamer »
I support this request too.
Dreamer
Post by Dreamer »
Added, but maybe a dialog (below) would be better:
[  "Close dialog after conversion"  ]
[  (o) Yes                  ( ) No  ]
[ [x] Do not show this dialog again ]
Whole Batch Convert dialog would be clearer I think.
This option could be added also to main Options.
What do you think?
Dreamer wrote:Added, but maybe a dialog (below) would be better:
[  (o) Yes                  ( ) No  ]
What do you think?
I think that only "close dialog..." is better and clear
Xyzzy
Post by Xyzzy »
In b3 there's checkbox Close dialog after conversion that works, so I consider this Solved.
X.
Locked
