Statusbar is invisible
KilliK
Post by KilliK »
Hello.
I updated xnviewmp to the latest version 0.98.4 64bits, and I discovered a problem with the statusbar.
The statusbar in viewer mode is not shown although it is enabled. I know it is still there, because if i toggle it on/off the viewed image becomes bigger or smaller to accommodate the new size of the internal window. Basically it is there, but it is invisible.
if i delete the xnview.ini file with the settings, the problem is fixed and the statusbar becomes visible.
but since i wanted to keep my old settings, the next fix is better:
i edited the ini file and removed from the [start] section, the entire line starting with geom=
geom=@ByteArray(\x1\xd9\xd0\xcb\0\x3\0\0\xff\xff\xff\xff\xff\xff\xff\xf8\0\0\n\0\0\0\x5\xa0\0\0\0\0\0\0\0\x17\0\0\t\xff\0\0\x5\x9f\0\0\0\0\0\0\0\0\n\0\0\0\0\0\0\0\0\x17\0\0\t\xff\0\0\x5\x9f)
that fixed it immediately and i keep the old settings.
I post this in case someone comes across this problem and for the developer to consider this bug in a future update.
