Freeze when read images into zip files
Hizoka
Post by Hizoka »
I use Kubuntu 20.04, but it's an old bug.
I click on zip file to open it without extract it.
I see images like into a folder.
I can open they files with many software but when I try to use XnViewMP, the soft freezes, it don't show the image, only grey screen.
I need to kill it, impossible to close it.
My terminal indicates be in the folder : /run/user/1000/kio-fuse-UBdSHO/zip/home/hizoka/Download/Partage/hajime-no-ippo-1352.zip
If I execute ls command, I see the images.
I launch another software.
ls command see the images.
but
I launch XnWiewMP.
ls command don't see anything !
Any idea why ?
Big thank you for this nice software !
Version 0.98.4 64bits (May 31 2021)
