Thumbnail display not showing
HerrBill
Post by HerrBill »
On opening, XnView no longer displays thumbnails in the thumbnail pane. Any suggestions as to how I can switch it back on again.
Re: Thumbnail display not showing
could you post a screenshot?
HerrBill
Post by HerrBill »
Screenshot as requested
What are your settings for View → Filter by, Bill?
The preferences for View → Filter by → Custom are configured in Tools → Settings… → File list → Custom filter.
HerrBill
Post by HerrBill »
Under custom filter, all boxes are ticked with the exception of video which is listed under the heading 'show as thumbnail'. I ticked this box but it had no visible effect.
if you use Filter by>Image, same thing?
HerrBill
Post by HerrBill »
Filter by image has done the trick. Thanks for your assistance. :)
Question 1, any idea how this option might have been switched off?
And 2, is there a quick, self help reference available that beginners/ newbies to XnView such as I, could refer to in time of need?
you have perhaps clicked on the icon
HerrBill
Post by HerrBill »
thanks
