I usually want to keep the original aspect ratio when cropping images, but XnviewMP doesn't do it well when I have both horizontal and vertical images.
2. click the crop button, set a aspect ratio, for example horizontal 4:3, crop and save.
2. click "next file" to open 2.jpg, click the crop button
Expected behavior: the aspect ratio to be vertical 3:4
Actual behavior (bug): aspect ratio reset to "free"
On the other hand, if 1.jpg is vertical and 2.jpg is horizontal, the aspect ratio 3:4 doesn't get reset to free, but doesn't change to horizontal 4:3 as expected.
aspect ratio forgetten
masterjp
Re: aspect ratio forgetten
For digital image editing (e.g. golden ratio) a very important function!
