Thanks for the latest version 0.99.1 release!
The JPEG XL Export dialog has a problem.
You can choose greyscale mode and you will not get a preview.
[Solved] 0.99.1 - JPEG XL Export - greyscale mode - no preview
masterjp
Re: 0.99.1 - JPEG XL Export - greyscale mode - no preview
it seems that JPEGXL library has some problem with greyscale image
masterjp
Okay, thanks for the hint.
Maybe this colour mode will be available in a newer release of JPEG XL encoder.
