This pictures makes XnViewMP crash
ElEsteban
Post by ElEsteban »
Subject: 0.99.0 Images make XnViewMP crash
XnView: MP 0.99.0 64bits
OS: Windows 10 64bit
Hi, I have attached 2 image files that makes XnViewMP, crash. I dont know if they are corrupted or something, but I have found this two. Also I dont know if this only happen in my computer :?:
Effect: Program crashes
1. Select folder where this files are stored
2. crash
Thanks :D
Re: This pictures makes XnViewMP crash
please update your version
ElEsteban
Post by ElEsteban »
Thank you, now it works fine. I have checked to check for updates daily, I think the update was there some days ago.
Thanks :D
