Information to display "Filename" doesn't included extension
kiwichick
Post by kiwichick »
XnView: MP 0.99.1 - 64-bit
OS: Windows 10 - 64-bit
In the Settings / View / Info tab, Information displayed has an option for "Filename without extension". This implies that the option for "Filename" will include the extension but it doesn't. This seems to be a bug because at the bottom of the tab window there is the "Title bar" field and it says "Filename With Ext" (this is what actually appears when "Filename" is chosen). If I manually change the entry in Information displayed to "Filename With Ext" it fixes the problem and the file extension is included.
UPDATE: I've just discovered that this bug also exists in the settings for Slideshow.
Effect: The filename extension is not included when "Filename" is selected.
1. Click Insert.
2. Select "Filename".
3. Click OK.
4. Open an image in fullscreen.
Actual behaviour (bug): file extension is missing :bug:
Expected behaviour: file extension is included.
Re: Information to display "Filename" doesn't included extension
In the Settings / View / Info tab, when you click on 'Filename', you have {Filename}?
kiwichick
Post by kiwichick »
xnview wrote: Tue Oct 05, 2021 2:17 pm In the Settings / View / Info tab, when you click on 'Filename', you have {Filename}?
Thanks for your reply. No I do not have that. I'm so sorry, I don't know what I was thinking when checking the options the other day. Must have been over-tired. I've tried again and I can see now that the options work as expected.
