XnView: MP 0.98.4 - 64-bit
OS: Linux (elementary os 6)
Effect: After restarting XnView MP, the folder is there again.
Folders cannot be deleted from the context menu.
1. In the left window, right-click on a folder and select Delete.
2. Confirm deletion.
3. Restart XnView MP.
0.98.4 Folder can not be deleted
Re: 0.98.4 Folder can not be deleted
Please try lastest version
Bassi
Thank you very much for the quick reply.
I have now found out that the problem only exists with the Flatpak installation!
Flatpak version Help > About... 0.98.4?Bassi wrote: Wed Oct 06, 2021 7:52 am I have now found out that the problem only exists with the Flatpak installation!
The Flatpak download on the latest version download page is unfortunately sometimes an earlier version.
Bassi
I have installed XnView MP from flathub.org https://flathub.org/apps/details/com.xnview.XnViewMP
XnView Version 0.98.4 64bits (May 31 2021)
Libformat version 7.81
my installed flatpack version: Flatpak 1.10.2
joshas
This is an issue with Flatpak runtime: https://github.com/flatpak/xdg-desktop- ... issues/518 . As a temporary workaround you can disable "Use Recycle Bin" option in General Settings, File Operations tab.
