here is a question that points to the future:
Will xnViewMP be compatible with Windows 11 or is advised not to migrate from Win 10 64bit?
Thanks in advance,
Otrag
XnViewMP on Windows 11
Re: XnViewMP on Windows 11
XnView should work on Windows 11, i need to install Windows 11 to check...
just installed Windows 11, and XnView MP & XnConvert works correctly
OTRAG
Hello Pierre,
Thanks for the quick reply.
So you have completely rebuilt Win11 and xnVieMP is running.
Can I conclude that xnViewMP will also work when upgrading on an existing Win10 platform?
Thank you, Otrag
Thank you, Otrag
Regards, Otrag
Rick
If it is working o Windows 10 then it should be fine under Win 11 unless something went horribly wrongOTRAG wrote: Thu Oct 07, 2021 6:17 pm So you have completely rebuilt Win11 and xnVieMP is running.
Rick
Rick
hic
I already upgraded from 10 to 11 and XnViewMP works just fine.OTRAG wrote: Thu Oct 07, 2021 6:17 pm Can I conclude that xnViewMP will also work when upgrading on an existing Win10 platform?
OTRAG
Many thanks to all!
So I will switch to win11 as far as is available for me.
Have a great time
Otrag
Have a great time
Otrag
Regards, Otrag
