Video tutorial
Video tutorial
Which subject will be great as a video tutorial?
- Batch convert
- Batch rename
- Change time stamp
Re: Video tutorial
All of'em :mrgreen: but if I had to choose one, I'd go for batch conversion, because that's XnView's most important and most powerful set of features.
Re: Video tutorial
XnTriq wrote: Fri Oct 08, 2021 1:00 pm All of'em :mrgreen: but if I had to choose one, I'd go for batch conversion, because that's XnView's most important and most powerful set of features.
All true, but isn't batch conversion reasonable self-explanatory if you work along the tabs from left to right?
On the other hand, aren't Batch rename and Change timestamp possibly more in need of explanation, and wouldn't those be shorter and so simpler to make to start with? Any lessons learned could then be incorporated in Batch convert.
