32bit export?
jxl
32bit export?
Post by jxl »
Currently, everything seems to be exported at 8bit, Even if you import 32bit OpenEXR.
PS: I export it to the TIFF format that supports 32bit, I get a 8bit.
github.com/GoogleChromeLabs/squoosh
Re: 32bit export?
XnConvert convert always with 8bits per component.
