0.99.1: Hidden file search doesn't work
stevehero
Even though Show hidden files & folders is checked in the File list settings the find files doesn't find them.
Perhaps a separate checkbox in the Find dialog would be a good solution?
Re: 0.99.1: Hidden file search doesn't work
right, 'search dialog' doesn't search hidden files, need a setting
stevehero
Hi, thanks for looking into this. It's still not working.
Windows version
BuildNumber Version
19045 10.0.19045
Windows version
BuildNumber Version
19045 10.0.19045
how do you reproduce?
stevehero
Just updated my portable version and searched for filenames that are hidden and it doesn't come back with any results.
It works here, do you have 'Show hidden files & folders' on?stevehero wrote: Wed Jun 21, 2023 10:11 pm Just updated my portable version and searched for filenames that are hidden and it doesn't come back with any results.
On windows 10, i hide some files and search
stevehero
Tested again.
The recurse through subfolders doesn't work, at least for me. I think that was why I had no results in testing.
could you post some screenshots?
stevehero
Here you go. Inside that other folder is another hidden file. It only finds the root folder one.
right i can reproduce, will be fixed in b4
stevehero
