B1: Minor: Obsolete scripts are not removed
Locked
Dreamer
Post by Dreamer »
- press ctrl+u
- save script
- press Esc
- remove script file from hard drive
- press ctrl+u
- select saved script
= script is obsolete and removed
- press Ecs
- press ctrl+u
= same script is there again
= sometimes script with strange characters is there, sometimes 2 same scripts (that have been removed before)
FlorianH
Re: B1: Minor: Obsolete scripts are not removed
Post by FlorianH »
Dreamer wrote:- press ctrl+u
- save script
- press Esc
- press ctrl+u
- press Ecs
- press ctrl+u
I agree
Dreamer wrote:= sometimes script with strange characters is there, sometimes 2 same scripts (that have been removed before)
I confirm, but i couldn't reproduce it.
Dreamer wrote: = sometimes script with strange characters is there, sometimes 2 same scripts (that have been removed before)
How to reproduce it??
Dreamer
Post by Dreamer »
Hard :wink: - but could you reprodusce at least this bug?
If so and you will fix it, also the other bugs could be fixed.
Try to remove all scripts before testing (from the list and hard drive, at least move them) and try "my" steps above.
Edit: screenshot:
marsh
Post by marsh »
When I highlight a recent removed script, it displays nothing unusual for me on Win2k. No odd characters. Maybe its OS specific?
Yes, because i don't check if file exist!
How to reproduce this bug??
Dreamer
Post by Dreamer »
xnview wrote:
Dreamer wrote:
xnview wrote: How to reproduce it??
I misunderstood.
Again - When the first bug will be fixed, also the second bug could be fixed, so try to fix the first bug and we will see then...
Maybe also some "Clear all" button would be useful here, or in Options...
Dreamer wrote:Maybe also some "Clear all" button would be useful here, or in Options...
Think this should go to the options (like all 'Most recently used' settings).
Greetings,
Helmut
Dreamer
Post by Dreamer »
Greetings,
Helmut
I agree. Maybe other similar option could be added, then - first option 'Most recently used files and dirs' would be for files and dirs and second, e.g. 'Most recently used options' would be for options, options lists... Other items could be added here later...
Dreamer
Post by Dreamer »
- save script
- press Esc
- press ctrl+u
- press Ecs
- press ctrl+u
1. = same script is there again
2. = sometimes script with strange characters is there, sometimes 2 same scripts (that have been removed before)
1. Not fixed.
2. Looks fixed, but hard to reproduce.
Dreamer
Post by Dreamer »
- save script
- press Esc
- press ctrl+u
- press Ecs
- press ctrl+u
1. Not fixed.
1. Fixed.
2. Looks fixed...
Closed.
Locked
