XnView MP v0.99.1 64-bits (Sep 23 2021): Crashes while browsing subfolders
sgt.Rapper
Post by sgt.Rapper »
XnView MP: 0.99.1 - 64-bit
OS: Windows 10 Pro, version 20H2 (OS Build 19042.1288)
Effect: XnView MP crashes
XnView MP crashes when navigating folders in the left navigation panel with the Folders tab selected. This happens when navigating certain folders. It seems to happen on folders that contain subfolders, but does not happen on ALL folders containing subfolders. I was unable to identify if this happens with folders with certain filetypes. The folders causing XnView MP to crash first show a spinning animation for about 2-3 seconds and then crash the program.
The crash is reported in Application Log with the following details:
Event 1000, application error
Faulting application name: xnviewmp.exe, version: 0.99.1.0, time stamp: 0x614c275f
Faulting module name: ntdll.dll, version: 10.0.19041.1288, time stamp: 0xa280d1d6
Exception code: 0xc0000374
Fault offset: 0x00000000000ff199
Faulting process id: 0xf58
Faulting application start time: 0x01d7cb6f0394423a
Faulting application path: C:\Program Files\XnView MP 0.99.1\xnviewmp.exe
Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll
Report Id: de1c2c61-0e39-4da4-922b-a02d09f6d9f5
Faulting package full name:
Faulting package-relative application ID:
1. Browse a folder structure with many folders each having subfolders (around 70 folders with each having a variable number of subfolders)
2. Select first folder and see if XnView MP show the folder's content, either subfolders or images
3. If it does, continue with the next folder until you see the spinning animation for 2-3 seconds and see XnView MP crash
Actual behaviour (bug): XnView crashes :bug:
Expected behaviour: No crash, contents of subfolder is displayed.
Re: XnView MP v0.99.1 64-bits (Sep 23 2021): Crashes while browsing subfolders
do you have sent a crash dump?
