<Mail address has been removed by moderator - please see Rules and Guidelines>
i have an *.1 extension (its a jpg)
how can i see the thumbnails in xnview?
<removed>
extension not showing as thumb nail
Re: extension not showing as thumb nail
You could rename your *.1 files to *.jpg and then view them with XnView, but I guess this is not what you want. By default, XnView interprets the file extension (.jpg, .gif, ...) to determine the file type. "*.1" extension does not mean anything to XnView so your file is not shown.iwanb wrote:<Mail address has been removed by moderator - please see Rules and Guidelines>
<removed>
This default behaviour can be changed: By unchecking the checkbox "Recognize only by extension" in Options dialog, category "Browser > File list" XnView will try to find out about the file format by checking the contents of the file. This will make XnView a bit slower, but you should see thumbnails for your *.1 files, then.
