Hide XMP files
gwmills64
Hide XMP files
Is it possible to prevent XMP files from displaying in the viewing window?
- Forum Librarian
Re: Hide XMP files
Does this solution work for you, gwmills64?Sirio wrote: Tue Jun 13, 2017 9:31 amIf you want to hide the xmp companion file or any type of file, do this it in the options:
- Tools> Settings> Browser>File list> Custom filter. In the string "Exclude"
add at the end of the line all the extensions that you wouldn't like to see.
e.g.:"xmp RAW RW2 ORF DNG PEF CR2 RAF ARW sfk sfl sfvp0".
In order to activate this filtering, then go in the menu: View> Filter by> Custom.
