Please add clean EXIF function also to the 'JPEG Lossless transformations'. I think it fits there since it doesn't alter the actual image quality.
XnView 1.82 <x>
b1:[Req] Add clean EXIF to the JPEG Lossless transformations
ckv
Xyzzy
Re: b1:[Req] Add clean EXIF to the JPEG Lossless transformat
Really, we have Metadata clean nowckv wrote:Please add clean EXIF function also to the 'JPEG Lossless transformations'. I think it fits there since it doesn't alter the actual image quality.
The "Delete EXIF data" could possibly go to the dialog as an option, but there shouldn't be another menu item in submenu "JPG lossless transformations".ckv wrote:Please add clean EXIF function also to the 'JPEG Lossless transformations'. I think it fits there since it doesn't alter the actual image quality.
Supported.helmut wrote:The "Delete EXIF data" could possibly go to the dialog as an option, but there shouldn't be another menu item in submenu "JPG lossless transformations".
X.
Xyzzy
