Ways to unassign a category from images
Gwenael Q.
Post by Gwenael Q. »
Assigning a category to an image can be done by various ways. Seems to me that unassigning a category is not so easily done...
It is a long time since the last time I used XnViewMP, I must be missing some obvious and quick techniques...
Thank you for listening
Re: Ways to unassign a category from images
Select the images, right click to open context menu
Or
Uncheck the categories in 'Categories' or 'Categories sets' panel
Gwenael Q.
I still didn't find how to unassign category this way...
- 'Categories' : This is the way I used to do but not very handy...
- 'Categories sets' : The quickest way... left-click on the category and it is done ! (discovered this just right now!!)
if you select a category, you have 'Remove from category' in context menu
Yes it's the better way
Gwenael Q.
Hello, thank you for replying
Still not able to find how to do.... some hint ?
select a category in 'categories filter' pane, right click on a thumbnail
Gwenael Q.
'Categories filter' was the trick !! :)
Thank you !
