I am using the free version of XnView MP (0.99.1 x64) but I cannot get favourites or layouts to save - is this a function of the paid version?
If I close the program and reopen it, it will return to the previous layout (one I have changed), but if I switch away and return the changes are lost. And while favourites appear to be saved, on closing and re-opening they disappear.
I have tried uninstalling, including removing all references to XnView in the registry, and reinstalling.
I am only using it as a browser, to view and delete photos pre-editing in Affinity Photo.
Cannot save favourites or layouts
Re: Cannot save favourites or layouts
could you post a screenshot of settings>Integration>Paths
henryg
I can't paste or upload a screenshot
It just puts the
tags in when I click on the picture icon.
But I can tell you that my ini file is located and is set for User (System) as are catalog (XnView.db) and thumbnails database (thumb.db). Other files are set to the program folder.
Those files are present at C:\Users\xxxxx\AppData\Roaming\XnViewMP, and the file modified dates change so they are being updated in some way, but the favourites are still not present when I reopen XnView.
Why other files are in 'program folder', XnView can't save themhenryg wrote: Wed Nov 10, 2021 9:16 am But I can tell you that my ini file is located and is set for User (System) as are catalog (XnView.db) and thumbnails database (thumb.db). Other files are set to the program folder.
henryg
Dunno, don't think I changed it, but setting it to User made no difference.Why other files are in 'program folder', XnView can't save them
Thanks for you input!
Now all settings are in 'User'?
henryg
Yes, but I changed the thumbnail from "same as catalog" to "User" specifically, and now seems to be working.
Thank you Pierre for all your help!
