B1: Zoom in/out in preview (in browser) doesn't work
Dreamer
Zoom in/out in preview (in browser) doesn't work, only with my old .ini file, it doesn't work also in 1.80.3, but it works good with the same .ini in 1.80.1.
I didn't find any option to enable/disable.
Pierre, I already sent my .ini to you, please check it out. Thanks.
XnView 1.82 -
XnView 1.82 -
Re: B1: Zoom in/out in preview (in browser) doesn't work
In a previous thread, someone ask to remove scroll for wheel mouse if View/Keyboard/Mouse Wheel is used for no zoom!Dreamer wrote:Zoom in/out in preview (in browser) doesn't work, only with my old .ini file, it doesn't work also in 1.80.3, but it works good with the same .ini in 1.80.1.
Dreamer
When the mouse wheel is used to switch images in FS, then it's useless in the browser. Also LMB+wheel / RMB+wheel to zoom doesn't work in preview, at least this should work.xnview wrote:In a previous thread, someone ask to remove scroll for wheel mouse if View/Keyboard/Mouse Wheel is used for no zoom!Dreamer wrote:Zoom in/out in preview (in browser) doesn't work, only with my old .ini file, it doesn't work also in 1.80.3, but it works good with the same .ini in 1.80.1.
I think it should be used to zoom always, or option to choose between "zoom", "switch images", "scroll" and maybe "do nothing" should be added.
It was very useful option, not only for me, but I can't find old topic about it...
Helmut, you agreed to remove wheel in preview (if not in options/view/keybaord), what do you think?? Perhaps a request of claudeDreamer wrote:When the mouse wheel is used to switch images in FS, then it's useless in the browser. Also LMB+wheel / RMB+wheel to zoom doesn't work in preview, at least this should work.xnview wrote:In a previous thread, someone ask to remove scroll for wheel mouse if View/Keyboard/Mouse Wheel is used for no zoom!Dreamer wrote:Zoom in/out in preview (in browser) doesn't work, only with my old .ini file, it doesn't work also in 1.80.3, but it works good with the same .ini in 1.80.1.
View and preview are related, so I'd expect the setting made for "View" to be applied to both image view and preview. Currently the behaviour differs, which is not good.xnview wrote:Helmut, you agreed to remove wheel in preview (if not in options/view/keybaord), what do you think?? Perhaps a request of claudeDreamer wrote:...
Not sure whether there is a need for different settings for image view and preview, I think only users can answer this.
In first instance I'd vote for same behaviour for both image view and preview as set the option.
Request of mine---
- Yes, I remember very well : it was related to this bug in the preview.
- And I'm quite happy to have the wheel disabled there now, while it is not configured for zooming !
Re: Request of mine---
Good that you have found the original topic, Clo.Clo wrote:Hello Pierre !
Kind regards,
And as I can see my mind hasn't changed, a quote from that thread:
"I think the one and only solution here is to make mouse wheel in Preview and View mode behave the same. If the user sets "Previous/Next" file for mouse wheel in View mode, he/she should have this behaviour for the preview, too."
Dreamer
Yes, but it doesn't work like that! Mouse wheel is completely useless there.helmut wrote:And as I can see my mind hasn't changed, a quote from that thread:
So again, at least LMB+wheel / RMB+wheel to zoom should be enabled in Preview.
And - why there shouldn't be any option for a mouse wheel in preview when it's used to switch images in FS?
No, if you have zoom for mouse whell, you can use it in preview!Dreamer wrote:Yes, but it doesn't work like that! Mouse wheel is completely useless there.
Dreamer
But if I have "switch images" for mouse wheel, it's completely useless.xnview wrote:No, if you have zoom for mouse whell, you can use it in preview!Dreamer wrote:Yes, but it doesn't work like that! Mouse wheel is completely useless there.
And - if I have "switch images" for mouse wheel, I can use at least LMB/RMB+wheel to zoom in FS, but I can't in preview - this is a bug I think.
Ok, i add itDreamer wrote:But if I have "switch images" for mouse wheel, it's completely useless.xnview wrote:No, if you have zoom for mouse whell, you can use it in preview!Dreamer wrote:Yes, but it doesn't work like that! Mouse wheel is completely useless there.
Dreamer
Thanks. What exactly, just LMB/RMB+wheel? I think, zoom for a mouse wheel, as option or always would be very useful and it's probably also very easy to implement, since it was already there.xnview wrote:Ok, i add itDreamer wrote:But if I have "switch images" for mouse wheel, it's completely useless.xnview wrote: No, if you have zoom for mouse whell, you can use it in preview!
Dreamer
Xyzzy
1st remark- move View>Keyboard/Mouse to General>Keyboard/Mouse, as it affects both Browser and Viewer AND it should be close to Switching modes, that also defines behaviour for keyboard and mouse. (Actually if they had fit, they should have been put on the same page.)
Behaviour for Preview/View should be identical. If an action cannot be performed in current context (like Selection in Preview) it should be ignored.
File list in Browser should follow standard Windows behaviour for such control.
X.
X.
Dreamer
