Among category properties there is a very clever one : the checkbox "Don't export", with the logic that some categories are created just for "categories management" and not for being applied on images (eg. "year", "subject", etc)
This logic could be carried a little bit further in order to be completely consistent. For now this property is used only on export of metadata. I would like to see it used also when applying categories.
I suggest for this a new setting option
F12 > Metadata > IPTC&XMP > ☑ Automatically apply parent keywords.
☑ Only apply exportable parent keywords
Thank you for listening !
Postscript 1 : "F12 > Metadata > IPTC&XMP" should be labelled "IPTC,XMP & categories" for the sake of clarity.
Postscript 1 : Does anyone know how to indent text in this forum without using code tags ?
Automatically apply parent keywords - Improvement request
Gwenael Q.
Re: Automatically apply parent keywords - Improvement request
yes, will be great. Not needed to have another setting checkbox in category properties?
Gwenael Q.
Hello
No, no need to have another setting checkbox in category properties for this improvement.
Gwenael Q.
Hello
For the sake of clarity :
F12 > Metadata > IPTC&XMP > ☑ Automatically apply parent keywords/categories.
☑ Only apply exportable parent keywords/categories
and what about Album feature which is for categories management only
it's not better to have a check box for 'Export children' instead 'Only apply exportable parent categories'?
