The photo file doesn't open with that message
gimecho
Post by gimecho »
The photo file doesn't open with that message.
It's a symptom that appears in version 0.99.1.
There's no error in version 0.95
Re: The photo file doesn't open with that message
Are you able to start XnView directly? Windows 10?
gimecho
Post by gimecho »
Yes, it's Windows 10 and you can do it individually.
When starting another program, an error message comes out from 0.99 If you install 0.95 it runs without errors.
you have this message when starting XnView from windows explorer?
