Refresh Search File
KnoX
Refresh Search File
Post by KnoX »
[ Introduction ]
Hi! lately, im working on a batch of images that i need to rename it manually to make it match from a database identifier. However, i have struggle for those mentioned suggestion that slowing down the renaming process.
[ Problematic ]
Upon renaming file, im usually using default Explorer search feature to list my images because the image have some "tex" prefix and the file would unlisted from the search result after renaming the file but this features doesnt work on XnViewMP. I already try to do the similar thing using "Quick Search" feature and the file wont updated/unlisted from the search result after renaming. I also try to refresh the list using "F5" but it seems its not updating anything.
[ Aftermath ]
I would love to see that feature as default or any work-around for this inside the latest XnViewMP.
-Thanks
