simple one two batch joiner
megetious69
Post by megetious69 »
THINKING GOOD WAY TO GET THROUGH MANY JOIN PROCESSES ,
WOULD BE A SIMPLE ONE TWO JOINING PROCESS ,
LIKE SELECT THE WHOLE FOLDER AND SIT BACK WHILE IT JOINS SET OF TWO PHOTOS SIDE BY SIDE,,
SKIPING OUT ON THE ODD BALL NUMBER SIMPLY LEFT OUT FOR A LATER JOIN ,,
JUST PICK A LIMITER TO THE SIZE OUTPUT
THIS CAN SPEED UP THE ONE BY ONE JOINING EVEN THOUGH YOU CAN PICK SEVERAL IN THE JOINER
ITS STILL A ONE BY ONE PROCESS WITH EACH JOIN TrY THAT ON A FEW MILLION AND YOU GET TIRED IN A FEW THOUSAND
FEELING LIKE A WHOLE LOTA WORKAHOLIC AT A WORKARAUNT
and i love to sit back and feel like the com is doing the work as intended
one last point just pick if it should be left right join or top bottom joins
then you could stack the process joining already joined twobies and so forth....
and great if ya got picosmos shows for sorting by "resolution"
then use "visipics" to set match levels if you dont want matching photos in the folder
but great way to compress the numbers down joining even before runing arts programs to effect many in place of one,,,
but great idea would love to see it this way ---otherwise love the app xnveiw mp ----
last sugestion overall format types? the fastest of all i have tried has been the painnt app from microsoft store,, better than their own photos app ,,hint two ,.apps dont seem to work smooth set to themself,,notice something other than their own seems to make other apps work better,, dont know why but i got some 12 million pics so i feel the drag on the switchs and which ones seem to load all the fastest has been painnt from moonlighting apps not too sure if totaly accurate on name titles then "faststone" for gifs xnveiw mp kind been sucking on giff outputs, hevey speckled blank spot blocky, tried several settings ,,but thats my sugestions and note of experience so far...
