b1: Problem: Use all formats avaliable and Write>File typ
Xyzzy
Post by Xyzzy »
As I understand, General>Startup>Use all formats available controls if not-most-used filetypes appear in Save As at all and Write>File types control which filetypes appear on this list in first places.
Deleted .ini file.
1.
General>Startup>Use all formats available unchecked (default).
Go to Write>File types, select None, click OK.
Reopen window, all file types are selected and in Save As window appear all filetypes with no selection of most-used at the beginning- both should not. Expected behaviour: After reopening Options file types should be unselected, only most-used types should appear in Save As window.
2.
Write>File types>The most used
All filetypes are avaliabe for save- should not
Expected behaviour: Only most-used types are avaliable.
Generally, it seems to me that General>Startup>Use all formats available doesn't work at all.
X.
Re: b1: Problem: Use all formats avaliable and Write>File
Xyzzy wrote:As I understand, General>Startup>Use all formats available controls if not-most-used filetypes appear in Save As at all and Write>File types control which filetypes appear on this list in first places.
'Use all formats' is to initialize xnview with the support of all formats...
1.
2.
No in the file list you have 2 lists, most used first!
I think this "Use all formats" is very confusing. I still don't understand when this should be used and what it is for.
xnview wrote:
1.
2.
We really need a seperator to split the most common formats from the rest. Currently it looks just like a long, long list.
marsh
Post by marsh »
helmut wrote: We really need a seperator to split the most common formats from the rest. Currently it looks just like a long, long list.
If that is not possible, perhaps part of list could be different font or colour?
Reason for another way---
:arrow: marsh
:) Hello B. !
- AFAIK, this does not seem possible (easily ?) with the used programming language…
- It's one more reason for which I proposed another way to get the most used¦usual types for “Save as…”
- Currently, that list stays as so impractical as formerly, as a long «solid» pack of lines, and doesn't solve the issues I encounter when making a lot of screen shots as prior BMP, then PNG one by one that need to be saved alternatively into two different target-folders…
:mrgreen: Kind regards,
A Clo's trick---
:arrow: Pierre
:) Hello !
- Although I think still that such a double-list won't do any good whatever(*), you could get a separator as following :
1. Create a fancy¦fake file-type either as
a) *.------------------------------------------- (needed number of dashes)
b) or as *.——————————————————— (#151, needed number of extra-long dashes)
c) or as (more visible and “XP-look”) *.• • • • • • • • • • • • • • • • • • (#149, needed number of bullets)
2. Place it at the right location in the list.
- Note :
<b)> and <c)> require that you CHANGE that awful f****** antiquated internal font in the EXE because they miss in it.
• For instance, "MS Shell Dlg" should be convenient since using "Microsoft Sans Serif" by default under XP and similar (same look), and allows to set any appropriate complete font under Win 9x using the section [FontSubstitutes] in <Win.ini>
- It should solve many other issues too…
:mrgreen: KR
(*) In French : "C'est un cautère sur une jambe de bois…"
Xyzzy
Post by Xyzzy »
xnview wrote:'Use all formats' is to initialize xnview with the support of all formats...
OK, but what is the effect of this option??? What happens if support for all format is initialized and what happens when it's not?
Fe.:
Go to Write>File types, Most used
(these are defaults)
I could easily save JPG file in Wavefront Raster Image. So it seems support for all formats is active after all, despite turning off the option?!?
[deleted by author]
I've written a whole epistle here but I changed my mind and deleted it. Please Pierre, just try to answer such questions form our point of view. I am sure that Use all format actually DOES something, but we don't know the code, we just use the application.
X.
Fe.:
If this option is enabled, you have more than 500 formats available in reading, if not the 100 most used
Xyzzy
Post by Xyzzy »
Thanks.
So I think this is a non-issue.
X.
Xyzzy wrote:Thanks.
X.
I think this is an issue: We have an option which does something which is not clear - even to experienced users. Not quite clear how to improve this, but something must happen here.
helmut wrote:
Xyzzy wrote:Thanks.
X.
Why? Standard user don't use this option...
xnview wrote:
helmut wrote:
Xyzzy wrote:Thanks.
X.
An option which noone understands what it does is always an issue. Novice users are irritated, standard users don't understand, either, and some power users reading this forum understand and know. This is no good.
helmut wrote:An option which noone understands what it does is always an issue. Novice users are irritated, standard users don't understand, either, and some power users reading this forum understand and know. This is no good.
Perhaps we can change label for "Initialize all supported formats"?
marsh
Post by marsh »
Or "Read all supported formats (500+)"
If name change is not enough, moving it to Options>Read would also help prevent it from being confused with file association or write types.
Dreamer
Post by Dreamer »
Maybe the problem is that users don't know what happens if this options is disabled...
[x] Use all formats avaliable
[ ] Don't use all avaliable formats ??
What about:
[x] Read the most used formats only (similar to Associations option)
Locked
