in the batch convert module, one can add folders but only one by one. It would be good to be able to select multiple folders at once.
Also, it would be useful to reopen the Add folder at the last location in order to avoid navigating the entire folder tree each time (less important if it is possible to select multiple folders).
Best regards
Batch convert - add folders
