Please enable saving file searches
Subjektiv
Post by Subjektiv »
Hi!
I always use the file search (in the upper section of the mask) with RegExp. But RegExp expressions are complicated and sometimes long. So it would be very helpful and nice to save them.
Database searches can be saved, but unfortunately not file searches. Could You please implement this feature?!
Thanks in advance!
Christian
Re: Please enable saving file searches
you can save current search criteria in search dialog
Subjektiv
Post by Subjektiv »
I am sorry, but I do not find any possibility to safe RegExp searches for finding komplex file names.
Am I missing something?
Thank You!
are you talking about search dialog? or quick search?
Subjektiv
Post by Subjektiv »
Hi!
It relates to the search dialog. Please look at the attached screenshot with an example of an RegExp search.
Thank You for Your helpfulness!
Subjektiv
Post by Subjektiv »
Now I did understand it. It works perfectly!
Sorry for the stupid question!
