Пользуюсь просмотрщиком XnView Classic, при перетаскивании в программу Adobe Indesign (2019) файла-картинки (pdf, jpg, tif, png - без разницы) Indesign зависает. При перетаскивании в Photoshop или CorelDraw - все нормально.
Пробовал другие просмотрщики (Проводник, Bridge, Imagine, Acdsee) - с ними все хорошо, никто не зависает.
Пробовал XnViewMP - все работает, ничего не зависает, но эта версия мне не удобна. Кроме того у меня она очень сильно тормозит, работать не возможно. Компьютер не очень мощный - на i3, 8 гб. Обычный щелчок по файлу и открытие - 10-15 секунд, хотя в XnView classic все моментально происходило.
Вот снял видео:
https://www.youtube.com/watch?v=wFydTdIfoQM
Система Windows 10 x64
I use the XnView Classic viewer, when dragging an image file (pdf, jpg, tif, png - no difference) into Adobe Indesign (2019), Indesign freezes. When dragging in Photoshop or CorelDRAW, everything is fine.
I tried other viewers (Explorer, Bridge, Imagine, Acdsee) - everything is fine with them, no one freezes.
I tried XnViewMP - everything works, nothing freezes, but this version is not convenient for me. In addition, it slows down very much for me, it is impossible to work. The computer is not very powerful - on i3, 8 GB. The usual click on the file and opening - 10-15 seconds, although in XnView classic everything happened instantly.
Here I took a video:
Windows 10 x64 system
Indesign freezes
- Forum Librarian
Re: Indesifn freezes
Brother Gabriel-Marie wrote: Wed Nov 17, 2010 10:37 pmI want to report a solution for a bug that I experienced. It isn't really a bug - just a shortcoming - and probably just of windows - but I am reporting it anyways. I was having trouble drag-dropping jpegs from the thumbnails view of XnView into Adobe InDesign CS3. It kept telling me that I either didn't have permissions or that the file didn't exist. But I could see the file both in XnView, FreeCommander and Explorer and had no problems anywhere except for this drag-n-drop operation. Then I narrowed the problem down that it was just with that ONE SINGLE folder. The permissions were right, nothing was read-only BUT - and this is where the solution lies - the name of the folder was called æsops. That was the problem. When I renamed the folder to aesops the problem went away and I could drag-drop till my heart was content. Note the difference between æsops and aesops - the first two letters in the first case were joined as a dipthong, hence, it was one character. It is part of the Latin1 codepage, I think. Just FYI in case anyone else experiences a problem like this.
Переведено с помощью www.DeepL.com/Translator (бесплатная версия) wrote:Я хочу сообщить о решении ошибки, с которой я столкнулся. Это не совсем ошибка - просто недостаток - и, возможно, только в windows - но я все равно сообщаю об этом. У меня были проблемы с перетаскиванием jpegs из режима просмотра миниатюр в XnView в Adobe InDesign CS3. Он постоянно сообщал мне, что у меня нет прав доступа или что файл не существует. Но я мог видеть файл и в XnView, и в FreeCommander, и в Explorer, и нигде не было проблем, кроме этой операции перетаскивания. Затем я сузил проблему до того, что она была связана только с ОДНОЙ ОДНОЙ папкой. Разрешения были правильными, ничего не было доступно только для чтения, НО - и здесь кроется решение - имя папки называлось æsops. В этом и заключалась проблема. Когда я переименовал папку в aesops, проблема исчезла, и я мог перетаскивать папки до тех пор, пока мое сердце не будет удовлетворено. Обратите внимание на разницу между æsops и aesops - первые две буквы в первом случае соединялись как дифтонг, следовательно, это был один символ. Это часть кодовой страницы Latin1, я думаю. Просто к сведению, на случай, если кто-то еще столкнется с подобной проблемой.
mlukyanov
Re: Indesign freezes
А почему в связки с Photoshop все нормально?
Эту проблему можно устранить или не стоит ждать?
- Forum Librarian
XnView Classic doesn't fully support cyrillic characters.
XnView Classic не полностью поддерживает кириллические символы.
mlukyanov
Благодарю Вас. Спасибо. Буду стараться использовать латиницу
