I have used more combinations of .\icons\info.png, but icons remain very little.
Is it possible to have (in future releases) the overlay icons more visible?
Two "info.png" versions, or "normal" and "2x" settings.
I use Windows at 100% scale, 27" display, 2560*1440.
XnView MP 0.99.4
Win 10x64
Overlay icons MORE visible?
Re: Overlay icons MORE visible?
Yes, overlay icons are small ...
Did you try this one ?
With colors, it is more visible
Catalogage avec XnviewMP :
cicciobello
Yes, I had test various color versions (also "homemade").
Colored icons it's a bit more readable, but it's always too little.
A +50% or +100% version would be really good.
