XnView: MP 0.99.1 64bits (Sep 23 2021)
OS: Windows 10/64bit
The photo displayed in the thumbnail is not the one displayed in the preview (shifting of one photo in the thumbnails). The preview is the right one.
Effect:
1. Test carried out: change of directory: correct in another directory
2. Return to the defective directory: incorrect again
Offset between thumbnail and photo
Thermometre41
Re: Offset between thumbnail and photo
you have always the problem with same file??
Thermometre41
Oui, avec le même répertoire.
Yes with the same directory.
Last edited by Thermometre41 on Sun Dec 05, 2021 10:45 am, edited 1 time in total.
even you select the file and View>Rebuild thumbnails?
Thermometre41
I didn’t tri it. Will do it right now.
Thermometre41
It worked! Thanks. I didn't know this option.
Have a good WE.
Jean-Michel
Have a good WE.
Jean-Michel
