I tried 4 different settings for WEBP output in the batch converter.
Filter strength and filter sharpness:
25 - 0
25 - 7
60 - 0
60 - 7
Files seem to be almost exactly the same. 2 of 4 files differ in length by 2 bytes. My eyes do not find any difference at all.
So - it is not working?
XNView 0,99,4/64 Windows 10.
Converter, WEBP filter options defunct
Tapio
Re: Converter, WEBP filter options defunct
Same problem in XNConvert, both versions up to date.
it depends on image, i have the same result as cwebp
Tapio
Are you really sure? Maybe you use broken libraries? It happened to all pictures I tested. It was forest scenery. Now I tried a totally different picture. A screenshot.
One is saved with filter=100, one with filter=0. Result: 2 bytes of difference as well. It's always 2 bytes difference. EDIT: This is on compression method 6. On compression method 2 the difference is 4 bytes.
Pictures were saved with XNView via "Save As".
I was not able to produce images with noticable differences in their results. If it is this way, you could remove the filter options.
do you have tried with cwebp?
Tapio
No, where can I get it, is there a Windows binary?
masterjp
https://developers.google.com/speed/webp/download
You can get the official WEBP encoder/decoder exe on the Google website for Windows and other operating systems.
Tapio
Thank you. Indeed, cwebp produces the same sized output. I cannot see under which circumstances the filter options do something significant. Visually I do not see a difference at all. Test image was landscape scenery with grass.
C:\Users\Tapio\Desktop\libwebp-0.4.1-windows-x64\bin>cwebp -f 0 20171113_110319.jpg -o out1.webp
Saving file 'out1.webp'
File: 20171113_110319.jpg
Dimension: 3840 x 2160
Output: 874194 bytes Y-U-V-All-PSNR 37.58 46.14 49.20 39.12 dB
block count: intra4: 31166
intra16: 1234 (-> 3.81%)
skipped block: 15 (0.05%)
bytes used: header: 407 (0.0%)
mode-partition: 159712 (18.3%)
Residuals bytes |segment 1|segment 2|segment 3|segment 4| total
macroblocks: | 3%| 19%| 43%| 33%| 32400
quantizer: | 36 | 32 | 26 | 19 |
filter level: | 0 | 0 | 0 | 0 |
C:\Users\Tapio\Desktop\libwebp-0.4.1-windows-x64\bin>cwebp -f 100 20171113_110319.jpg -o out2.webp
Saving file 'out2.webp'
Output: 874196 bytes Y-U-V-All-PSNR 37.58 46.14 49.20 39.12 dB
bytes used: header: 411 (0.0%)
mode-partition: 159711 (18.3%)
filter level: | 19 | 12 | 11 | 8 |
C:\Users\Tapio\Desktop\libwebp-0.4.1-windows-x64\bin>cwebp -f 0 -sharpness 0 20171113_110319.jpg -o out3.webp
Saving file 'out3.webp'
C:\Users\Tapio\Desktop\libwebp-0.4.1-windows-x64\bin>cwebp -f 0 -sharpness 7 20171113_110319.jpg -o out4.webp
Saving file 'out4.webp'
filter level: | 0 | 0 | 0 | 0 |-
masterjp
It is possible, that you use a very old webp encoder (version 0.4.1)? Your folder is named libwebp-0.4.1-windows-x64.
The latest webp library has the number 1.2.1 and you can find it here:
https://storage.googleapis.com/download ... ws-x64.zip
Although there is a new release candidate 1.2.2 version available:
