XnViewMP 0.99.4 - Creating and Renaming of directories - could not open them in browser window
masterjp
Post by masterjp »
Since Version 0.99.x there is a bug in browser window, which should be new.
I tested the same problems with the earlier version 0.98.4 and they do not exist!
Maybe the new QT library or XnViewMP itselfs make these problems.
1. I started XnVievMP with Browser window.
2. Create a new directory within the current directory (e.g. D:\Test)
3. The directory is created and shown correctly in browser window
:bug: If I try to open the folder with a double mouse click in the big file and folder area, it is impossible to open it :!:
The same problem I will get, if I rename an existing folder and try to open it.
:arrow: The only way to solve this problem is to change the active directory to another and go back to the previews folder. Pressing F5 for window refresh does not solve the problem.
I have admin rights.
Both problems I could test in a previous version of Xnviewmp 0.98.4 and this version works perfect.
Re: XnViewMP 0.99.4 - Creating and Renaming of directories - could not open them in browser window
