Seg Fault when pressing delete key
solcuerda
Post by solcuerda »
OS: Manjaro KDE (all up to date)
XnViewMP: 0.99.5
As subject line says, pressing the DELETE key causes a segmentation fault and XnViewMP disappears. It doesn't matter what's selected, be it file or folder, or nothing selected at all.
Pressing delete on the toolbar works fine.
zsh: segmentation fault (core dumped) xnviewmp
Re: Seg Fault when pressing delete key
This problem is supposed to be fixed in XnView MP 0.99.6. Please check and confirm the bug fix here.
solcuerda
Post by solcuerda »
That was quick! Can confirm it's working great again.
Thanks for that. :D
