When i use „select all images“ in a folder- they are not selected..so i have to click 600 images per hand to export them ? Have to change arw files to tiff files…
Thx a mill for your fast replies
Export complete folders
Re: Export complete folders
Have you looked at Tools > Batch convert... ?Oliwal wrote: Sat Dec 11, 2021 8:27 am When i use „select all images“ in a folder- they are not selected..so i have to click 600 images per hand to export them ? Have to change arw files to tiff files…
That would be the obvious way to apply the same action(s) to many images...
Oliwal
Thx a lot- I’ll give it a try!
