Hi! I wonder if it's possible to resize canvas size in a square format by the longest side with nconvert command line.
I've seen the function in XnView MP, unfortunately when i export the line doesn't work (with teh .bat file)
Thanks in advance
Resize canvas by longest side with nconvert
polsino
Re: Resize canvas by longest side with nconvert
you have
-canvas longest-
polsino
Thanks. Can you tell me which argument I have to set after "longest" to make my canvas square?
I''ve only found an example with argument in mm, but it's not what I'm looking for
- canvas longest 220mm-
you can use
-canvas longest 200
