[0.99.6] "Fit image to window" incorrect on retina
lolmaus
Post by lolmaus »
Hi! Using 0.99.6 64-bit on Windows 10 Pro.
When I use "Auto image size" → "Fit image to window" on a non-retina display, the result is correct:
However, when I move the window to a retina display, the image is resized incorrectly. Here's an example for a 150% retina factor:
Apparently, some part of XnViewMP is accounting for the retina factor in its calculation while another part doesn't.
lolmaus
Re: [0.99.6] "Fit image to window" incorrect on retina
Post by lolmaus »
I would like to add that this hasn't been the case previously. This bug is a regression introduced at some point.
it was always like, if you click on 'fit image to window'?
lolmaus
Post by lolmaus »
xnview wrote: Wed Dec 22, 2021 12:18 pm it was always like, if you click on 'fit image to window'?
I don't understand the question, please rephrase.
I would like to add that this happens only to images that are smaller and should be stretched in "Fit image to window" mode. Images that are larger and should be shrunk are fine.
Perhaps you had 'settings>View>Zoom on HiDPI screen...'?
lolmaus
Post by lolmaus »
xnview wrote: Wed Dec 22, 2021 1:50 pm Perhaps you had 'settings>View>Zoom on HiDPI screen...'?
Yes, unchecking that checkbox resolved my issue, thanks!
But I still think there's a problem with it enabled. If that behavior is intentional, why does it only affect smaller images?
lolmaus wrote: Wed Dec 22, 2021 1:55 pm But I still think there's a problem with it enabled. If that behavior is intentional, why does it only affect smaller images?
On HiDPI screen, when enabled the image size doesn't use pixel scaling
lolmaus
Post by lolmaus »
Well, this option breaks "Fit to window" for smaller images, doesn't it?
lolmaus wrote: Thu Dec 23, 2021 5:07 am Well, this option breaks "Fit to window" for smaller images, doesn't it?
No, why? Perhaps i don't understood the problem?
