Huge Menu Fonts
ventolinmono
Huge Menu Fonts
Post by ventolinmono »
Hi
Using XnView MP Linux Version 0.99.6 64bits (Dec 10 2021) and suddenly the fonts on the menu are huge. Tried complete reinstallation but the problem persists. How can i reduce the font size? Cant' find an option for this on Settings.
Here's how it looks:
Re: Huge Menu Fonts
suddently? do you have changed something?
ventolinmono
Re: Huge Menu Fonts
The only thing I can think of is that it has something to do with Tweaks, the program I use for enlarging or reducing fonts for the whole system. I have a scaling factor of 1.7 but whether I reduce or enlarge fonts with this, Xnview doesn't change and I can see it affects the whole system and other programs.
Thanks for the quick reply! :mrgreen:
ventolinmono
Re: Huge Menu Fonts
Any ideas what this might be?
Re: Huge Menu Fonts
do you have changed the display font scaling?
ventolinmono
Re: Huge Menu Fonts
Yes, but it doesn't affects Xnview.
Re: Huge Menu Fonts
There is some issue when using no integer scale factor
ventolinmono
Re: Huge Menu Fonts
Thanks for the answer Pierre :D
