XnView: MP 0.99.6 - 64-bit
OS: Windows 10 - 64-bit
There is a regression in 0.99.6 where it is no longer possible to open the file's location after searching for it. The last version I tested and it worked was 0.99.1.
Effect: Nothing happens after trying to open the file's folder from within the program (not to confuse with "Open file in explorer").
1. Go to "Categories Filter" or "Tools > Search...".
2. Filter one or multiple files via categories, ratings, color labels etc.
3. Right-click a file from the search result.
4. Select "Open Containing Folder".
Actual behaviour (bug): The browsing/viewing mode stays with the filtered files, not showing the actual file location.
Expected behaviour: The program should change from viewing the filtered files, to opening the selected file location along with any other files present.
0.99.6 "Open containing folder" option no longer works.
Re: 0.99.6 "Open containing folder" option no longer works.
The last version I tested and it worked was 0.99.4; Windows.
This problem is supposed to be fixed in XnView MP 0.99.7. Please check and confirm the bug fix here.
It was fixed in 0.99.7 and still works properly in v. 1 beta 4.
